821jay's avatar
821jay
2016 Dodge 2500
I currently haul a 2005 lance 821 (around 4000lbs loaded) on a 2004 dodge 2500 short bed. I am thinking about upgrading to a 2016 or newer dodge and noticed that they went to a coil spring in the rear. Is anyone hauling this kind of weight on a newer dodge and if so what kind of mods have you added to your truck?
  • Go to this link
    pick your new truck.
    click on base weights/GVW Payload/Trailer tow
    on 2500's the highest payload is 3990 on a 4x2 reg cab long box gas engine truck.(and that 3990 has to include you and other passengers plus gear in truck. Highest 2500 GAWR rear is 6500
    now on 3500's, payload is still around 3930 on Single Rear wheel trucks with rear GAWR of 7000 lbs.
    move up to dually and your payload and rear axle weight jumps around 2500 lbs or more.
    click on Camper Guide
    This will show you "remaining cargo" which is after the ram engineers deduct weight for what a max load of passengers would weight. Most of the 2500's are around 1500 lbs.
    even in the 3500's to see numbers of 4000 lbs your looking at GVWR of 14,000 or 13,300 which I have a feeling are both duallies.
  • camp-n-family wrote:
    At minimum you're going to need airbags to help the soft springs. Whatever you do, none of it will increase the trucks ratings that you'll need to carry that weight. No 2500 has 4K payload. You'll also be exceeding the axle and likely tire ratings too.
    If your looking to buy, why not just get the 3500 and not worry about it? The price difference is minimal. I just factory built identically equipped 2500 and 3500 trucks and the difference was less than $300. No point in starting under equipped.
    X2 Go 3500. You will not regret it.
  • At minimum you're going to need airbags to help the soft springs. Whatever you do, none of it will increase the trucks ratings that you'll need to carry that weight. No 2500 has 4K payload. You'll also be exceeding the axle and likely tire ratings too.
