Dalehacker
Feb 05, 2016Explorer
Update, received my torklift mounts and they did not fit. A call to torklift has a replacement set on their way. Excellent customer service. The units I received had the box dated 5/24/2014 by the bar code and they have apparently been redesigned using the same part numbers. The frame holes on the 2016 Dodge have been moved approximately 1/2" up. So if you order a set check the manufacturer date by the bar code on the box. Note only the passenger side front mount was incorrect. The drivers side front and both rears fit correctly.
