- LwiddisNomad IISorry that huskie didn’t respond with max trailer weight and payload.
- BoomerwepsExplorerWith the towing package (HD/ 53A) 9,000# GVWR trailer is a reasonable pull with data we have. IOW, 7-7,500# dry. There are several towing with the 2.7EB at 7,000#.
- bikendanExplorer
huskyfan68 wrote:
3.5L with trailer tow package
which tow package, regular/HD/or Max Tow package? - Grit_dogTrailblazer
gbopp wrote:
Grit dog wrote:
I predict you'll hear more about how that is too much trailer for a half ton than you will meaningful input germane to you question. But icbw.
The OP is inquiring about a Ford. I think the germane's build Volkswagen and Mercedes-Benz. :B :B
Was it over when the germanes bombed Pearl Harbor??
What movie? - APTExplorer6k dry for half tons. That truck has plenty of power, but GVRW and rear axle ratings will be over at 7k+ pounds. Also, those that have towed with half tons at 7k dry (8-9k loaded) tend to comment on stability and comfort level of towing at highway speeds.
If you want a 7-9k dry TT, get a 3/4 ton. Any 2011+ will do. If you find something in the 6k dry range, then I recommend the 2017+ F-150 with 10spd trans. - LwiddisNomad IIWhy, huskie, are you avoiding telling us your max trailer weight and payload?
- gboppExplorer
The OP is inquiring about a Ford. I think the germane's build Volkswagen and Mercedes-Benz. :B :B - GrooverExplorer III have a 2016 with the 3.5 Ecoboost and max tow package. I use it to pull a lot more than than that on a regular basis. I am generally the only one in the truck with no more than a couple of hundred pounds of cargo so I stay within the truck's GVWR. I do occasionally through another 1,000lbs in the bed and really can't tell the difference.
The truck was factory equipped with the special order LT tires, Load Range C, and I added 2,000lb air bags plus Rancho 9000 shocks. I never pulled without that stuff so I can't tell you how much difference it actually makes. Plenty of power, as solid as my old F250 and stops as well as your trailer brakes work. But that is true for any truck. Of course I use a load distributing hitch but do not use an anti-sway bar.
I haul equipment, not a camper so your aerodynamics may not be as stable as mine. I hear that 20" wheels offer the same or better stability as my 18" with LT tires do.
I found the F150 with a good hitch to be easier to drive and more stable than a 2019 F250 with a weight carrying hitch. - huskyfan68Explorer3.5L with trailer tow package
- LwiddisNomad IIMore information please OP.
44,065 PostsLatest Activity: Apr 12, 2026
