Sportsmen's avatar
Sportsmen
Explorer II
Mar 10, 2019
2016 F250 tranny
Still trying to figure out the 6 speed in my new to me 2016 F250 gasser. I put it in tow/haul mode but the engine is only turning 1500 rpm at 60 mph which causes lots of downshifting on overpasses, etc. I think I figured out you can lock out 5th and 6th gears using the electronic shift control on the gear shift lever.
I am interested in what others are doing to maintain a little higher rpm to eliminate a lot of downshifts.
My old truck only had a 4 speed tranny and locking out the O/D the engine would run around 2300 RPM at 60 mph which eliminated a lot of downshifts.
Thoughts ??
  • I had a 2012 f250 which I believe had the same tranny. It was always downshifting and screaming high rpm's when towing. I used to get concerned on some of the long incline's I pulled on. Bought a 2017 diesel dually f350 and found it a totally different pulling experience.....
