SouthpawHD wrote:
I know Ford has had some frame supply problems on the F150. Perhaps it is impacting the SD line as well. And I'm guessing the problem is bigger than they are leading on.
The F-150 is being built in three 10 hour shifts at 2 plants, while the F-250 - 550 is built in a entirely different state, and has totally different suppliers.
I am not sure when the change over will happen from 2015 to 2016, usually they give the factory employees a 2 week vacation during shut down, when a lot of maintenance workers are working overtime! Your dealership should have told you all of this, as it happens each summer! They should have you on a schedule, even if it says September. Perhaps they do not want to tell you the schedule.. . .
Good luck,
Fred.
