d3500ram wrote:
Wardster wrote:
Photomike wrote:
I am curious, did you try lifting the camper with the jacks? If so did the bulge go away?
Yes, the bulge is almost unnoticeable when the TC is on the jacks, which should help with the repair.
Whether the bulge goes away irrespective of on or off the truck is unacceptable IMHO. For a new, less-than-one-year old camper a repair should not be necessary for this. It might be indicative of a much more serious nature. Did it do this when you took delivery or is it recent?
I agree that it should not do it and it should be fixed.
All I wanted to know with my question is if it was a weakness (as would be indicated with the bulge that would go away when put on the jacks) or if it was permanently like that(no change when jacked up) so could be from the forming process of the fiberglass, something pushing against the fiberglass from behind, etc.
If it goes away when jacked up then I would say something has given way.
Hope it is fixed quickly for you!
