Well you bought an RV. They all suck, but a few brands suck a little less. I've had a few "high end" RVs (Safari/Monoco motorhome, Airstream trailer) and some of the workmanship on them was appalling. Even fraudulent. Maybe the best example is the awnings mounted with self tapping screws, a couple of them snapped off in the hole, so they hacksawed the heads off of some screws and siliconed them to the holes to cover it up - I'm not kidding, I have pictures! These are the screws removed from the new Safari, supposed to hold the window awnings on. Note the the screw head has clear hacksaw marks. It was glued over the hole, down in the hole was a snapped off screw. One on the other side, too. The reason I took them off was they hadn't used any sealant at all, rain water was running in the hole, down some 120V wiring, and pouring out of an electrical outlet. That's not supposed to happen :E.
