sch911
Sep 14, 2017Explorer
It sounds like you had a dead battery. Once you plugged in your converter began charging it back up. That's probably when you checked the charge and it showed full. Two things: You'll need to disconnect the battery when the TT is in storage as there are parasitic draws that will kill it in a few days of sitting, and You need to keep a close eye on your battery as they are not intended to be completely discharged like that. Good luck!
44,056 PostsLatest Activity: May 04, 2014
