nevadanick's avatar
nevadanick
2016 Ram 2500 stuck in 4th gear
Happened to me a couple days ago. Happened to a freinds truck. The dealer had the part there to fix another one and used it on mine because we were from out of town. Anyone else ? Seems common. Solenoid pack was the problem.
  • Perrysburg Dodgeboy wrote:
    The 68RFE is no different than the Ford or GM transmissions when you add a tuner box to the truck. They all will fail if pushed past there intended limits.
    True... but some just have higher intended limits than others.
  • I had a 2004 Dodge Cummins with a 48RE.
    If you left it in tow/haul it would stay in 3rd.
    Check your tow;haul button and your owners manual.
    It may be some thing simple.
    Good luck.
