nremtp143
Oct 04, 2017Explorer
ivbinconned wrote:
That will work 143. But make sure to install in the line an inline filter of no less than 3 micron.
The one I use was used in GM 6.5 trucks I understand. It has a threaded fitting at both ends so you can fit barbs on for the hose. I'm on the road right now but when I get home could post the part number.
Thank you for the suggestion. I was talking with a friend of mine about this today. I will give it a go at trying to find it.
Edit: Found it, but will a filter that size gravity feed?
