jus2shy
Sep 15, 2016Explorer
Cabman 850 wrote:
3500
OK, in the case of the 3500, they use fewer leaves (I think it's only 1) to locate the axle, along with 2 or so "Half-leafs" that prevent axle wrapping. Then the air bags over the axle provide the primary support for a heavy load. So when you are unloaded, the airbags run a lower pressure and should give a softer ride. When laden, the airbags receive more pressure and return to the stock riding height.
I'm sure the airbags will be a maintenance item, but they tend to last a pretty long time.
Found a link to a trailer life forum where a member shows his 3500 air suspension setup: Trailer Life Link Of course it's this website with a different url on it, but this came up on google first and I was too lazy to find it here.
44,056 PostsLatest Activity: May 04, 2014
