Cabman_850's avatar
Cabman_850
2016 Ram 3500 SRW tire size
Looking at new trucks and notice that several new trucks are coming with 18 or 20" tires. I will be hauling a 4000 lb TC. Any preferences on size and why? Thanks in advance!
  • Cabman 850 wrote:
    Trying to get them to switch to 18" due to price and selection, but they would not budge. They have a truck for the same price, but it has the air suspension which I know nothing about.
    Which weight class? 2500? or 3500? they're different for air suspension.
  • Trying to get them to switch to 18" due to price and selection, but they would not budge. They have a truck for the same price, but it has the air suspension which I know nothing about.
  • Yep, you have cheaper and a larger variety of options at 18" though. It's a far more common size. I think the Ford Superduty uses the same size as well for their 18" option. They have a taller 20" option.
  • Both the 275/70R18E and 285/60R20E have a 3,640 lb capacity at 80psi.
  • Looking at 2016 Ram specs shows the 18" and 20" tires at 3640 lbs
    And both wheel sizes at 3500 lbs.
    As poster above says check out tire prices/size choices and availability for a 18" and 20" LT E tires.
    I'd get whatever you can get the highest load rating LT tires in for a reasonable cost. Right now I think 18" LT tires are a bit more common than 20". You might want to go to 19.5" if you can for commercial truck tires.
