CharlesinGA
Sep 21, 2020Explorer
The cover is 14 bolts. It is a metal and rubber, reusable seal, so unless it is damaged in some way, it should be just fine. Carefully wipe it off and examine both sides of it. New ones are expensive, about $45 or so. There are no drain plugs and you should pull the cover and examine the insides.
Do NOT use any sealer on this seal, just wipe it off and possibly wipe a fresh film of gear oil on it.
GM uses the same basic rear end on many models but they use a throwaway gasket.
Charles
Charles
