Ron3rd's avatar
Ron3rd
Explorer III
Sep 12, 2020
2016 RAM CTD Diff Oil Change Question RE Gasket
When you changed the oil in your differential, did you install new gasket or re-use the old one?
  • The advice I got on my F350 was to use the Permantex Differential gasket gunk and forget the gasket. It's worked so far on both differentials
  • I have changed the fluid in both diffs on 2014 twice already and still have the stock gasket.
  • 2003 Ram 3500 dually 258,000 miles. Have always re-used the OEM gasket Clean housing and gasket well and you will be good to go!
