- blofgrenExplorer
FishOnOne wrote:
wanderingbob wrote:
Can you not suck the oil out and not open the case ?
You sure can as this is the method most dealers use. Unless there's a drain plug.
But you won’t be able to have a look at the ring and pinion and clean the magnet. Not good IMHO. - Cummins12V98Explorer III"And I've heard the "Right stuff" gasket maker works awesome."
It's DA CHITZ!!! NEVER had a leak using it.
You sure can as this is the method most dealers use. Unless there's a drain plug.- wanderingbobExplorer IICan you not suck the oil out and not open the case ?
- Grit_dogNavigator III
agesilaus wrote:
The advice I got on my F350 was to use the Permantex Differential gasket gunk and forget the gasket. It's worked so far on both differentials
In a pinch, I've used silicone window caulking or manhole mastic in similar applications.
But that was't the question and reusable rubber gaskets are a nice departure from smearing gasket goo on surfaces. - FishermanExplorer
Well they're not talking about fix or repair daily. - Grit_dogNavigator IIIIt’s reusable.
- Geo_BoyExplorer IIThe AAM 11.5” differential in my GMC 3500 has a drain plug in the bottom of the main housing.
- Ron3rdExplorer IIIThanks for the info folks.
- IdaDExplorerI've reused mine thus far. Why it doesn't come with a drain plug is question for another thread but stupid.
44,056 PostsLatest Activity: Nov 19, 2013
