SoCalDesertRid1
Sep 01, 2016Explorer II
ShinerBock wrote:The truck is a 2001 model year 4800 crew cab 4wd 33,000 GVWR. I have the original build sheet for the truck. I'll look up what it says about horn. It lists everything the truck was built with.SoCalDesertRider wrote:What is the model do you have? better yet, what is the last 8 of the VIN and I can pull up bill of material look up to tell you exactly where it is unless it is too old to have an electric horn and grandfathered in.
I have 2 air horns in the fender well, which are activated by the pull cord above the driver door. There no other horns that I have found on the truck and there is no switch in the center of the steering wheel, or anywhere on the dash. I am the second owner of the truck. The first owner was the Federal government. The truck was all stock when I got it.
*The truck has 0008WHE Air Horn Accomodation Package
