ShinerBock
Sep 02, 2016Explorer
SoCalDesertRider wrote:
The truck is a 2001 model year 4800 crew cab 4wd 33,000 GVWR. I have the original build sheet for the truck. I'll look up what it says about horn. It lists everything the truck was built with.
*The truck has 0008WHE Air Horn Accomodation Package
I have factory International software, if I had the last 8 of the VIN then I can verify. You are the first person I have every run into to have an actual bill of materials sheet for their truck unless it was given to you by a dealer. Although the bill of materials sheets I am referring to to do not lists packages and only list every part that was put on that truck by part number.
