SoCalDesertRid1
Sep 02, 2016Explorer II
ShinerBock wrote:The build sheet was provided by the International dealer, specific to the VIN number. It shows main assembly part numbers (part number for whole axle assembly, whole engine assembly, whole transmission assembly, etc, but not part numbers for individual parts of main assemblies, for example). The truck was originally upfitted as a brush fire truck for the US Forest Service. I don't want to give out my VIN number on an internet forum...SoCalDesertRider wrote:I have factory International software, if I had the last 8 of the VIN then I can verify. You are the first person I have every run into to have an actual bill of materials sheet for their truck unless it was given to you by a dealer. Although the bill of materials sheets I am referring to to do not lists packages and only list every part that was put on that truck by part number.
The truck is a 2001 model year 4800 crew cab 4wd 33,000 GVWR. I have the original build sheet for the truck. I'll look up what it says about horn. It lists everything the truck was built with.
*The truck has 0008WHE Air Horn Accomodation Package
