- rhagfoExplorer III
Cummins12V98 wrote:
spoon059 wrote:
Cummins12V98 wrote:
We humans can SEE what's in front of us.
Let me correct that for you... We humans have the ABILITY to see what's in front of us. Observing other drivers on the road, it is quite apparent that they don't see what is in front of them until they are on top of it... You know those guys, the ones cruising along in the left lane where there are signs for miles alerting to the left lane being closed. They are the morons that drive in the left lane, clip at least one traffic barrel before they realize that the lane is ending, then they usually cut into lane 2 and slam on their brakes, causing a chain reaction behind them... all because they didn't chose to exercise their ABILITY to see what is in front of them...
I REALLY miss my air horn for those exact reasons! A little blast will wake their AZZ up. :B
Only a about $100 separating you and a very nice set of Kline Air Horns. You already have air on the 2015.
The horns on my 2001 sounded like they belonged on a Kia! Now when needed I have a fitting voice. Geeze wrote:
FishOnOne wrote:
Here's the Ram pulling 30k lbs up the Ike Gauntlet.
Enjoy...
Link
I like the Mr.Truck Gauntlet videos just to see how the transmissions perform vs engine RPM's. The Chevy HD2500 6.0 gas beat the Ram 6.4 by over a minute and they made a big deal out of it. I don't know anyone who would buy one over the other because of this small difference. Both are fine trucks as is the Ford Super Duty 6.2.
The way I look at these tests is the one that pulls the load up the Gauntlet in the least time is the one that will pull a load the easiest with less drama.- GeezeExplorer
Enjoy...
Link
I like the Mr.Truck Gauntlet videos just to see how the transmissions perform vs engine RPM's. The Chevy HD2500 6.0 gas beat the Ram 6.4 by over a minute and they made a big deal out of it. I don't know anyone who would buy one over the other because of this small difference. Both are fine trucks as is the Ford Super Duty 6.2. - Cummins12V98Explorer III
I REALLY miss my air horn for those exact reasons! A little blast will wake their AZZ up. :B - ShinerBockExplorer
transamz9 wrote:
Actually no brakes are needed. It just has to sense your foot on the pedal. Basically turn your brake lights on.
That is considered a brake tap within the perimeters of the "test" and would be a score against Ram. So no, full mode would not be the ideal mode to be in for the parameters of this "test" to get the best score. I am not sure why you keep debating this?
transamz9 wrote:
This is the problem, people want everything to be "Automatic" and it's just not possible if one wants to get 100% efficiency out of something. I think the test that these people do should be done by someone that knows how to get the most out of a particular truck. That would show the consumers what the truck can actually do.
I agree that the test is stupid and is purely just for e-peen comparisons between fanboys to say their favorite does something better. Real truck owners who would be towing that much weight would not completely rely on the truck to do it all. I am just saying that if one wants to compare apples to apples in a test where you are trying to avoid brake taps and letting the truck to it all then Auto mode is the mode to be in. - transamz9Explorer
ShinerBock wrote:
transamz9 wrote:
The EB in full mode will work just as hard as auto mode you just have to touch the brake pedal to tell the truck to downshift. You don't have to manually shift it.
True, but in a test where you are scored on brake taps and you want the truck to do it all, full mode is not the mode you want to be in.
This is the problem, people want everything to be "Automatic" and it's just not possible if one wants to get 100% efficiency out of something. I think the test that these people do should be done by someone that knows how to get the most out of a particular truck. That would show the consumers what the truck can actually do. - BedlamModeratorWe rely on you lighting them up and educating them since they don't get the message any other way.
- spoon059Explorer II
Let me correct that for you... We humans have the ABILITY to see what's in front of us. Observing other drivers on the road, it is quite apparent that they don't see what is in front of them until they are on top of it... You know those guys, the ones cruising along in the left lane where there are signs for miles alerting to the left lane being closed. They are the morons that drive in the left lane, clip at least one traffic barrel before they realize that the lane is ending, then they usually cut into lane 2 and slam on their brakes, causing a chain reaction behind them... all because they didn't chose to exercise their ABILITY to see what is in front of them... - Bionic_ManExplorerWhat happened to the standardized MPG test that they were doing (level ground, 65 MPH...)? I remember seeing one on a RAM 2500, and the mid size GM, but nothing sense.
- Grit_dogNavigator III
Cummins12V98 wrote:
When descending Ashland pass coming into Oregon on I-5 for example with full EB and TH on I set cruise to 55 and lock out 3rd gear with 33K combined weight and it holds down the pass no problem. I am running in the high 2K rpm range. If I choose 4th it will hold most of the way but will creep up and need to touch the brakes lightly and hit resume on cruise.
EXPERIMENT is all I can say. We humans can SEE what's in front of us.
And also personal preference. In the situation you describe, I wouldn't reef on the engine at near max rpm just to save a tap or 2 on the brakes.
The capability of the new pickups gets more impressive every year, but now it's a contest to see who can get to the bottom without ever using the service brakes?
I'm more inclined to pick an option that is in the moderate range of all systems, rather than maxing out one and not using the other.
Now if you have to ride the brakes down in 4th, then by all means, use all the engine braking rpms you can in a lower gear to save your brakes.
44,056 PostsLatest Activity: Dec 27, 2025
