Perrysburg_Dodg
Jan 27, 2017Explorer
The issue Ford and GM will have with their 9 and 10 speeds will be holding the vehicle in those last two gears. Just like FCA is having with the 9 speeds. Customers do not like having their vehicles shifting in and out of gears.
That would be why Ford (haven't seen any reviews on the GM twin) has softened up the shift to where you can no longer feel them. They even commented on the fact that "you can't even feel it shift". A soft shift can only be done by slipping into the next gear. OK for lower HP and TQ vehicles not so much for higher HP TQ vehicles.
ZF has no plans to build a ten speed transmission.
MOTEGI, Japan -- Stefan Sommer, CEO of German supplier ZF Friedrichshafen AG, says his company won't follow rivals in pushing for 10-speed transmissions.
Automakers have been adding gears to their automatic transmissions in a bid to boost fuel economy. Ford Motor Co. and General Motors have unveiled plans to jointly develop 10-speed transmissions for use in cars, crossovers, pickups and SUVs. Volkswagen AG also has confirmed a move to 10 gears.
But Sommer said ZF's offerings will top off at nine speeds. The head of the company, one of the world's leading transmission suppliers, spoke this month at a Japanese racing event here, just north of Tokyo.
Fuel efficiency, he said, is derived from the range of gear ratios covered, not simply by the number of gears. ZF's range is wide enough now that incremental gains are difficult.
"We came to a limit where we couldn't gain any higher ratios. So the increase in fuel efficiency is very limited and almost eaten up by adding some weight and friction and even size of the transmission," Sommer said. "We will not go for 10."
Don
Don
