- 4x4ordExplorer III
transamz9 wrote:
FishOnOne wrote:
FishOnOne wrote:
Cummins12V98 wrote:
FishOnOne wrote:
otrfun wrote:
Cummins12V98 wrote:
Agree, for those that may have plans to do any DIY maintenance, lifting the hoods on both trucks is a dramatic study in contrast.
. . . Just lift the hood on both trucks, that should help with the decision . . .
Speaking of maintenance you forgot about the impossible location of the oil filter on the ram. The Ford on the other hand is right next to the oil pan like it should be.
ram oil filter mess
Ford Oil filter
Give me a break! Sure it's not as easy as the previous models but NO way is it hard at all! Certainly not as hard as cab removal!
I had a thread on TDR "EASY 2013 up oil change". How about posting a link for me of my thread???
I would never recommend removing the intake to the turbo to access the oil filter. Bad idea
I don't see where the problem is. I've probably had the turbo tubes off my Ford 6.0 more times than the oil filter has been changed and haven't had a turbo issue yet.
A bad idea is to design an engine that has to have the cab removed to do much to it. That's what you call opening a can of worms right there.
I think designing a truck that requires lifting the cab to do major work to the engine is a good idea so long as easy lifting of the cab is designed into the truck. There really is no reason why a truck couldn't be designed such that lifting the cab is less than a 20 minute job. With the cab out of the way any engine would be very accessible for major work.. - Me_AgainExplorer III
I did for 14 years on my 2001.5 RAM and am doing it on my 2015 RAM. Gives clear access from the top to change the filter. Lot easier that changing the filter on my two Cummins B150's in the boat for 19 years via the braille method. - transamz9Explorer
FishOnOne wrote:
FishOnOne wrote:
Cummins12V98 wrote:
ram oil filter mess
Ford Oil filter
A bad idea is to design an engine that has to have the cab removed to do much to it. That's what you call opening a can of worms right there. - transamz9Explorer
larry barnhart wrote:
Looks like the 2017 f-350 is the truck of the year if that means much.
chevman
I always thought it was funny how a truck could be crowned the truck of the year before the year even starts. LOL You would think that now would be when they are crowning the best truck of the year for 2016.
That's like saying "transamz9's NCAA basketball team of the year is... The Kentucky Wildcats" I mean we did beat a team last week by almost 100 points. - larry_barnhartExplorerLooks like the 2017 f-350 is the truck of the year if that means much.
chevman FishOnOne wrote:
Cummins12V98 wrote:
ram oil filter mess
Ford Oil filter
I would never recommend removing the intake to the turbo to access the oil filter. Bad ideaCummins12V98 wrote:
ram oil filter mess
Ford Oil filter
I had a thread on TDR "EASY 2013 up oil change". How about posting a link for me of my thread???Cummins12V98 wrote:
IdaD wrote:
With one of those end cap oil filter wrenches on a ratchet changing a filter out on the current Cummins is cake. Once you get it loosened up you just drop it in a ziploc, seal it up and pull it through the hole. I have no idea where the myth came about that it's a difficult job.
Do you pre fill filter as recommended?
I do.....:B- Cummins12V98Explorer III
Do you pre fill filter as recommended? - otrfunExplorer IIEdit
44,066 PostsLatest Activity: May 12, 2026
