proxim2020 wrote:
I have rubber valves on the inner wheels on my 18' DRW. If you have the factory plastic valve extenders try removing them and filling up the tires. It can be difficult to fill up the tire using those plastic extenders. The end of the plastic extenders are narrower than a standard schrader valve so you have to be perfectly aligned to get an air into them. It's much easier to just put the chuck right on the valve. Also get a longer air chuck. I had a shorter 5 in long air chuck and struggled to get it aligned properly. It's much easier to align with the 9 inch chuck that I use now and can fill the inner tires with ease.
You're right that you won't get an alert for your pressures since the truck came with a TPIS (Information System) instead of TPMS (Monitor System). However, it's not necessary to have the the pressure screen up all the time. Just scroll to it every once in a while to view the pressures.
I have a long air chuck now and I agree that the extensions are what make it a pain.
The problem I have with the just checking the TPIS screen once in a while is this is time you have to mess with you info center and scroll through it and it is a distraction from driving. Also you could just have looked at the screen and gone back to the gauge screen and with in minutes you could run over something and start leaking air and never know it especially with one of the rear duals. That is why I like having my TPMS monitor my tires all the time and alarm me when I'm losing pressure.
I think I'll go with the metal valves the Scott gave me a link to this way I can still have the dash reading and I can add a solid extension to it with a dounut hole rubber support for the extension. This would allow me to put my TPMS doggle on the end of the tire.
In case you folks can't tell I'm paranoid about my tire pressures and like to keep an eye on them. If one on my monitors stop sending and I get and alarm from it I'm looking for a place to pull over and check what is going on.
For folks that don't believe in TPMS my wife and I were heading out in our Jeep one day and I switched lanes and I heard a thunk and asked my wife if she seen anything I ran over. She didn't but down the road about 8 miles just when we started to hit stop and go traffic I got a tire pressure alarm and the tire was going down at a pretty good rate. We finally got to an exit and there was a Walmart there and we pulled in and the took the Jeep right in. A few minutes later they came in and asked me if I wanted what was left of the screwdriver that I ran over. All that was left was about a 8" shank and the tip of the screwdriver. The shaft was bent at almost a 90* angle. They checked the tire all over and the tire looked fine and did not see that it hit any cords. So patched it and we were on our way and never had a bit of trouble with the tire.
Another time on my wife's Toyota Highlander we were driving along and the TPMS chimed and I pulled over and the was a nail in the sidewall of the tire. We weren't that far to the Toyota dealer so we pulled in there and they put the spare on and we weren't that lucky that time as we had to get a new tire for it.
So maybe you can see why I like having TPMS on the vehicle.
