Venom4u's avatar
Venom4u
2017 F450 vs F350
I currently tow 43ft Jayco 377RLBH. I tow with a 2007 F350 dually.
Couple things.
1) The pin weight on the Jayco is just about 3000 lbs.
2) I have 6 people in the truck plus a 100lb dog.
3) I think the tow wieght is around 14k lbs.
I currently feel my vehicle does an OK job. But it could use airbags. I'm a inch or so away from the touching the overload Springs when all loaded up, full fuel etc.
It's a heavy load and I believe a 2017 with the newer engines would do a better job with it.
So I'm thinking 350 or 450. The 3500 mega cab was also in the mix but the mega cab isn't really bigger interior wise than the Ford and it had a short bed.
That said the 450 is listed as not able to carry as much load in the truck itself. I'm a bit confused because on paper the 350 looks like it works better with a bigger payload since I am way under Mac towing capacity of both trucks.
Many have said that the f450 is underrated.
I have read the 450 has a tighter turn radius which is nice.
So I am a bit torn. 450 sounds like a great rig... But being less capable of load bugs me... Should I really worry?
Opinions please...
  • The F450 is considered heavy duty construction truck. It's only warrantied for 36000 mls. unlike the F350 @ 100000 powertrain. The Mega cab has a much bigger cab but bigger cab means lower tow ratings
