Chuck___
Oct 04, 2020Explorer
The above Dually Kit and valve stems systems will not work if you have tire monitoring system for your truck or vehicle. The Factory valve stem have a special type senors that sends a signal to the vehicle tire pressure monitor on the dash read out. If you change the valve stem to the simple sit as above, you will no longer be able to monitor the tire pressure in the cab. I have a 2017 Ford 350 Dually.
Thanks IAmichbod anyway.
Charles
Charles
