4x4ord
Aug 13, 2016Explorer III
"Has anyone seen payload info on the new SD? I read all the gross towing specs, however I haven't seen the payload info. We'll be on the market later this year, and we want to stick with a SRW. "
Your probably aware that on the Ford website most of the Payload numbers are listed as to be determined. I think the truck is supposed to be about 300 lbs lighter and have heavier axles and stronger frames so because my 2016 SRW diesel cc 4x4 has a payload of around 3400 lbs I am quite confident that the 2017 will be at least 3700 lbs. How much payload are you needing?
