Rich1961
Jul 30, 2016Explorer
FishOnOne wrote:Cummins12V98 wrote:
Troy I really don't care what the "capacity" is so please tell me what the RAWR on the 350 and 450 Dually's are.
Same ol bolt on fenders sort of a combo of the last two styles.
Is there actually an engine under all that plastic and tubing???
Very weak Puck system placement/attachment still as B&W will only rate their hitch to 20K, same exact head on a RAM hitch is rated at 25K.
I actually think it's a good looking truck and with a Gas engine it's one I would consider for sure!
F450 RAWR is 9900 lbs. From what I understand the F350 and F450 use a similar rear end now.
I actually prefer the Ford fenders over a ram for two simple reasons: Access to the bed on the Ford is better over the swooping ram fenders that block access. And simplistic repair. I can replace a ford fender without the truck even entering a paint both.
There's actually a very big engine under that hood.
After owning a 6.7 Powerstroke for 4 years I would take it over any gas engine offering.
Also the long wheel base trucks have a 48 gallon diesel tank
Troy,
What rear axle is that? Obviously it's not the same as the 2016 F450. It looks big, but not as big as the previous model. Maybe a way to shave some weight from the truck as the S130 was probably a bit overkill for the pickups.
Rich
