Mbranscum's avatar
Mbranscum
2017 GMC 6.0 Vortec - Manual Shifting?
I notice when I am towing my RV, my truck seems to try and down shift sometimes when climbing a hill before it should. Do any of you guys manually shift to get more power or save gas in these situaltions?
Or do you just let the computer control it and go with the flow?
I believed I have a 4.10 rear end with a 6.0L Gas engine.
Thanks.
Mike
  • My 2001 3500 8.1 gas would downshift when towing quicker than I wanted it to do but that did keep the speed up. With the 05 duramax It wants to stay in the gears longer than what I feel is ok so I hit the button to go out of overdrive and let the engine run free. I think your truck is doing the same.
    chevman
  • OK..so when should the +/- manual shift switch for on the shifter be used?
  • Ok, I'm not sure what you mean by "before it should." Maybe you misspoke?
    If indeed you meant before, lugging the engine is bad for efficiency. You will use far more gas letting the engine lug down before shifting, than letting the transmission shift and the engine rev up. The engine has a range of RPMs where power and efficiency are optimum, and modern automatic transmissions are designed to keep the engines in that range.
    Lots of discussion lately in towing threads about downshifting and letting the engine rev, and many people claim they get BETTER fuel economy by doing that than forcing the engine to lug down.
  • SidecarFlip wrote:
    Always keep in mind that when an automatic trans up shifts or down shifts, thats is when the box makes the most heat.
    It makes heat through hydraulic actuation and it makes heat as the clutch packs engage under heavy load and gear ratio selections are programmed to feel smooth. It's the smooth feel that makes the heat (and wear) because the clutch pack hydraulic pressure is modulated for smoothness. That slipping makes the heat.
    While I don't have a GM, I manually downshift out of OD into direct prior to ascending a hill when the motor isn't producing a gob of power (Torque) and the clutch packs can engage with less residual heat. I run a shift kit as well and my shift kit increases the hydraulic pressure and how fast it rises, thereby clamping the packs quicker.... less heat
    I might be wrong but you don't ever want your clutch packs to slip. You want your torque converter to do the slipping. That's what it's for.
  • Always keep in mind that when an automatic trans up shifts or down shifts, thats is when the box makes the most heat.
