FishOnOne
Jan 06, 2017Nomad
Bedlam wrote:FishOnOne wrote:
The problem using too much def will cause the exhaust to clog up over time
Excessive particulates will clog the exhaust, but I don't see how excessive fluid will. Are you sure you not mixing up between DPF and DEF.
I'm sure... The particulates I'm referring to is the DEF crystallization that will form in the exhaust when too much is applied.
Link
