- dodge_guyExplorer II
GeoBoy wrote:
The ground clearance is 8+", the rear differential or front suspension lower arm would hit an obstruction before the DEF tank.
I guess you have never been off-roading? - DadoffourgirlsExplorer
OH48Lt wrote:
Go up over a curb, the front suspension will clear that way. Move forward 2 more feet and you're buying a new DEF tank. Did that once on a former 2005 F250 diesel, tweaked the left running board and they sit a lot higher than that DEF tank.
The guy that designed this must have gone to the same community college as the guy who designed the 2017 Fiat/Ram front grill.
How big of a curb are you talking about? Is this just a parking curb where the height is the same on both sides, or a curb onto a lawn?
Please let me know, I may be able to get video of this! - DadoffourgirlsExplorer
Bedlam wrote:
Ford also used have the gas tank inside the cab behind the seat. I'm not sure who came up with idea first.
BTW: Did GM move the DEF fill port or is it still under the hood? I'm assuming that it has not changed.
It is still under the hood. - N-TroubleExplorer
STANG23L wrote:
I wonder if patent infringement came in to play? And forced them into using that location?
Just a thought.
Seriously??? - jmckelvyExplorer
otrfun wrote:
........It's hard to believe the engineering team at GM couldn't have done a better job of hiding that DEF tank. It's just a big ole wart on an otherwise fine looking truck.
My sentiments exactly. That tank is just plain ugly. - ACZLExplorerWhy couldn't GM put the DEF tank by the fuel tank like Ford and Ram did?. Plus Ford and Ram still have room for larger aftermarket fuel tanks along w/ the DEF tanks in same location.
- BedlamModeratorRam was the last one to go to DEF in their pickups, so location placement should not have been an issue. I don't know how the underside is organized verses the others because even my chassis cab has some differences compared to the same brand pickup model. For example: I don't have the under floor storage like the crew cab pickup due to my larger DEF tank.
- STANG23LExplorerI wonder if patent infringement came in to play? And forced them into using that location?
Just a thought. - OH48LtExplorerGo up over a curb, the front suspension will clear that way. Move forward 2 more feet and you're buying a new DEF tank. Did that once on a former 2005 F250 diesel, tweaked the left running board and they sit a lot higher than that DEF tank.
The guy that designed this must have gone to the same community college as the guy who designed the 2017 Fiat/Ram front grill. - BedlamModeratorFord also used have the gas tank inside the cab behind the seat. I'm not sure who came up with idea first.
44,051 PostsLatest Activity: Sep 24, 2025
