Bedlam
Oct 20, 2016Moderator
Contact Randall at Host for an option sheet with MSRP prices. We are getting 3x160w solar, Fantastic Fan instead of Heki, Full wall cab over wardrobe, Prewire only for TV's and some additional modifications to the umbilical connections.
No one other than Lance is using cab over struts - I'm not sure any of the structures from other manufacturers were designed for an underside load. The Host camper height is 9.5' if you include the AC - Do you want store or carry items up that high on the roof? Rearview camera is a $900 MSRP option.
Your F350 will be over GVWR and close to rear axle capacity with the Mammoth. If you also plan to tow behind your setup, you need a bigger truck. I suggest skipping the F450/4500 and going to a F550/5500.
