Reality_Check
Oct 20, 2016Nomad II
zb39 wrote:GeoBoy wrote:Bedlam wrote:
Contact Randall at Host for an option sheet with MSRP prices. We are getting 3x160w solar, Fantastic Fan instead of Heki, Full wall cab over wardrobe, Prewire only for TV's and some additional modifications to the umbilical connections.
No one other than Lance is using cab over struts - I'm not sure any of the structures from other manufacturers were designed for an underside load. The Host camper height is 9.5' if you include the AC - Do you want store or carry items up that high on the roof? Rearview camera is a $900 MSRP option.
Your F350 will be over GVWR and close to rear axle capacity with the Mammoth. If you also plan to tow behind your setup, you need a bigger truck. I suggest skipping the F450/4500 and going to a F550/5500.
Randal can say what he wants, Bedlam has researched this camper thoroughly and when he tells you that a 550/5500 is what you need to carry this camper safety and comfortably you should listen to him and not your pocketbook.
No offense but Bedlam can say what he wants. I will listen to the guy that works at the factory. Maybe Bedlams does weigh 6k. But everybody packs differently and gets diff options. Either way I didn't expect this kind of anger and hostility, I have better things to do and I wouldn't want to be responsible for someone getting upset and having a stroke.
Once again, my public education is failing me. I can't read anything in this that is angry or hostile. Dammit, I miss all the good stuff.
Or perhaps I'm just not sensitive enough. Better tighten up the panties...
Bedlam isn't a salesman... that's the difference, I believe, that was being emphasized. Just good, useful, food for thought. Based on experience and reality.
Carry on..
