Geeze
Apr 26, 2016Explorer
sch911 wrote:spud1957 wrote:
And since there is no vacuum when the engine is off, the ventilation flips to defrost at every stop light. Maybe it's just me but I found it irritating.
The JGC Like ALL current FCA NAFTA vehicles is an all electric HVAC control system. In a stop event what you're hearing is the recirculation door moving to 50% in order to prolong cabin thermal comfort in the vehicle during the stop.
And I should know, I'm the Engineer. Yes we OEM engineers do watch these forums!
Has the issue with the cam gears slipping on the camshaft in the VM diesel been fixed? I've seen several You Tube videos reporting the problem. Apparently the gear is just a slip fit on the cam and a bolt in the end of the shaft keeps it in place. If the gear rotates the valves hit the top of the pistons. The last thing I want to do it buy a new truck and then pay someone else to "bulletproof" it.
44,072 PostsLatest Activity: Aug 23, 2026
