TurnThePage
Apr 27, 2016Explorer
Geeze wrote:It looks to me like this issue is a one-off. All the different hits I found lead back to the same guy.
Has the issue with the cam gears slipping on the camshaft in the VM diesel been fixed? I've seen several You Tube videos reporting the problem. Apparently the gear is just a slip fit on the cam and a bolt in the end of the shaft keeps it in place. If the gear rotates the valves hit the top of the pistons. The last thing I want to do it buy a new truck and then pay someone else to "bulletproof" it.
44,072 PostsLatest Activity: Aug 23, 2026
