"I haven't seen a tire dealer NOT use a torque wrench in probably 10 years."
YEP they sure do use a torque wrench! Watch em they run the lugs up with a torque stick. Then they go around once with a click at each lug not rotating the handle one bit other than to get a click. No second circular torque. YEP they sure do have good customer service!!!
Let's not forget the HIGH quality of their parts they use. Less then 30k the front caliper piston is frozen and won't retract causing metal to metal on one side and the other pads still had 1/4" pad left. This is on the 01 Sport I bought last Summer.
See anything wrong with the pic below? 98 RAM 2wd, receipt in glove box showing LS did the "WORK".
