Sunnyside42's avatar
Sunnyside42
2017 SD trailer tow rating
Hey Folks,
I'm 80% through the selection process and realized I should probably go back and check my travel trailer tow rating math. I'm looking at the 2017 Super Duty specs and I'm trying to determine which limit applies to the F250 I'm currently negotiating.
On this page (link) I see two max trailer tow ratings 15Klbs and 17.6Klbs. The truck config is as follows: F250, 4x4, SCrew, 6.7, lariat
Last question. If the payload sticker is 2190 and I load up say 1,100 pounds on the hitch does that mean I can put another 1090lbs of people, fuel and stuff in the bed?
Thanks!
  • transferred wrote:
    Given that the OP clearly stated he's looking at diesels, with due respect yours is an irrelevant post lacking accuracy. An identically equipped F350 SRW 6.7 does not have only "480 pounds" of capacity than an F250 6.7 it has more than 1,000 pounds. Go check the website. Hopefully you're not one of those 3/4 ton owners who think the door sticker doesn't matter.
    I'm not sure where you get your information, but from the booklet available from your local dealer, highlighting what it probably the most common configuration (At least on the lots around me), and what the OP was looking at (crew cab, short bed):
    F250, 10000GVWR 3450
    F350, 10000GVWR 3240 Yup 210 pounds less
    F350, 11500GVWR 3930 My calculator shows that as a mere 480 pounds
    Yes, these payloads are for a stripped down model, but every option selected should subtract the same across the board. Not only can I read stickers, but I can also read published charts.
    I can see why the booklet is confusing, as it makes no differentiation (typical for OEMs). . But reason the 10k F250 and 11,500 F350 srw have such a similar (500 lbs) listed payload is because the 3/4 ton has a gasser and the 1-ton a diesel.
    With the same engine the two vehicles have c.300 lbs between them as regards curb weight so do the math.
  • 4x4ord's avatar
    4x4ord
    Explorer III
    So I'll say it again: An F350 diesel equipped the same as an F250 diesel can carry about twice the hitch weight as the f250.
    Not quite twice, but it's much more. My '15 F-250 had a cargo capacity of 2204 (max vehicle weight 10k) and my new '17 F-350's capacity is 3477 (11.5k max vehicle weight). The 2 trucks were nearly identically equipped, crew cab, diesel, 4x4, Lariat,etc.
    I made a list of 12 5th wheel toy haulers and found that I would only comfortably tow 2 of the 12 with the 250, and both would have been legally overweight and reliant on air bags to be level. So upgrading to a 350 was an easy decision. It makes trailer shopping a little more difficult, but now I can get exactly what I want and not worry about pin weight.
    My advice to anyone who will be towing, especially if you are near your trucks weight limits, or concerned about weight, just go to the next higher level of truck. I wish I would have got a 350 in '15, but we weren't planning on a 5th wheel at all back then.
