fivebmc's avatar
fivebmc
2017 surveyor 200 mble
I have a 2017 surveyor 200 mble. had some issue with hanger and axle not positioned right , I have new axles and hangers to put on but I want to make sure everything is correct. If some has this surveyor and would please give me the measurements that great AXLE HANGER MEASUREMENT PROCEDURE - DOUBLE AXLE Measurement from front cross member to Center of center hanger then measurement from center hanger to center of the other hangers .Then distance center to center axle to center axle.
1 Reply
  • Welcome!
    If you don't get measurements that you trust, and you're skilled enough to actually cut off spring hangars and re-weld, I would suggest figuring it out yourself. Not hard to layout, plus, unless it was really jacked up, your center to center between axles should remain the same. But again, this is easy to figure out and you wouldn't want someone's subjective measurements.
