burningman
May 04, 2019Explorer II
Louder audio will do more for you than the insignificant power gains had by “turning up” a stock radio. The mod limiter on those Cobras is a little potentiometer on the circuit board you can twist with a small screwdriver... you just want to turn it up a bit, short of a distorted overmodulated mess bleeding over across four channels.
If you want more power, just get a 100-watt amp. That will work a whole lot better than so-called peaking a stock set.
And get a better mic. The stock mic is usually marginal.
