ShinerBock's avatar
ShinerBock
2018 Ram Cummins Towing 12.5k mpg
10.87 mpg! Not great, but not bad considering the brick it was towing. The Ford Powerstroke they tested earlier was 10.05 mpg which still is not bad.
2018 Ram 2500 HD Cummins MPG towing test
How do the gasers compare towing the same 12.5k lb trailer?
Ford 6.2L - 8.59 mpg
Ram 6.4L - 7.34 mpg
Ford F250 and Ram 2500 mpg tow test.
I know, I know, it is not apples to apples since the gasers were base model regular cabs and the diesels were decked out crew cabs 4wds.
  • rhagfo wrote:
    mich800 wrote:
    FishOnOne wrote:
    Thanks for sharing... It's interesting that some report the on board fuel economy readout is very close to calculated fuel economy and some report theirs are not even close. These both runs from both trucks were very close.
    I have found most of the vehicles I have driven from all makes are pretty close. Still need to be aware when doing one tank tests as the click off can really impact the calculation in the short run.
    Well on my 16 year old Ram the computer reads high by a consistent 1 mpg to hand calculated.
    I should have prefaced that comment with; more recent vehicles within the past decade. Also, the older the vehicle gets the harder it will be for the computer calculation as injectors and the general tune of the engine can stray from the ideal parameters it was designed for.
  • rhagfo's avatar
    rhagfo
    Explorer III
  • Lots of 6.2 Ford fans, yes, me too. I average about 8.5. I have gotten 10+ a few times, under ideal conditions, with all time low 7.8. My speedometer reads about 2 mph fast at 60 mph, so could make my mpg look just a little better than actual.
    Jerry
  • Thanks for sharing... It's interesting that some report the on board fuel economy readout is very close to calculated fuel economy and some report theirs are not even close. These both runs from both trucks were very close.
