Busdriver
Nov 21, 2020Explorer II
2019 Duramax Regen
If you have a L5P Duramax Don’t let them do the update for regens, mine used to to 4 to 6 hundred miles between regens, after the recall now 2 to 3 hundard miles
NRALIFR wrote:4x4ord wrote:
When Ford starts a regen that gets interrupted the regen is canceled till the filter reaches 100% full before initiating another attempt.............
That’s the way mine works, and there have been a few trips that just weren’t allowing a full regen to occur. It’s maddening to see that happen several times in a row. I wish when the DPF gets above about 80% soot load, it would allow you to start a manual regen. There have been too many times that if the ECM would just start the regen at the beginning of a short trip, it would have plenty of time to finish by the time I reach the destination. Instead, it seems to wait until just a few minutes before I get to where I’m going. Then it only has time to burn off about 10% of the soot.
