bkenobi
Jun 18, 2022Explorer
I have some 3M tape that I used with the TC to confirm the source of a leak. I just used it to seal off the lower skirt and fender extension. I ran around a gallon of water all around the window and no new water in the wheel well. I removed the tape a little at a time and found that the leak is in one specific location at either a screw or the unsealed gap above it on the fender extension.
Are these typically just screwed on or do they use butyl tape as well? Seems liek butyl tape would be best so I'm assuming they would save the money and not do it. Since it needs resealing anyway I'll have to pull the plastic and see what I'm working with.
