bkenobi
Jun 21, 2022Explorer
After talking to a couple local dealers, I've decided that cleaning with Acrysol to remove the silicon is a best bet. Then I'll use squares of butyl tape on the screw holes to properly seal and use proflex caulking. The only problem is that two of the screws are behind the skirt and I'd rather not remove the whole skirt right now. If I can fix this leak without having to do that, I can get some use out of this thing.
Screw hold on right may be the source of the leak. The others on the fiberglass should be simple to deal with. The one on the lower left (one matching on opposite end) is going to be challenging to seal unless I can reach it from under the skirt.
I pulled the opposite fender flare and didn't see any corrosion on any of the screws (though they forgot to install one lol).
