bkenobi
Jun 30, 2022Explorer
Double_Haul wrote:
The plastic fender trim is just decoration, and on my trailer, has nothing to do with sealing the unit. It shouldnt require any butyl tape.
My wheel well sheet metal was never sealed against the siding at the factory and resulted in water gathering and rotting the osb floor. Major work to fix.
Sounds like this situation. What did you use to seal the metal wheel well to the wall? I'm heavily leaning towards cutting the spray foam flush and installing a strip of 2" eternabond. I can access most of the length currently but would have to pull the metal skirt to access the last few inches front and back.
