bkenobi
Jul 05, 2022Explorer
PButler96 wrote:
I would scrape off the spray foam. Re attach the sheet metal, mask off inside the skirt line and spray everything with rubberized undercoating, then reinstall the skirts back caulking the screws, followed by caulking them with geocell proflexRV.
I reread your comment and think I understand your intent. The sheet metal was held onto the side of the trailer with ~3 screws for the entire ~6' span. I believe you are suggesting to add more screws to properly attach the sheet metal to the side and then use undercoating spray to cover the joint. Once cured, reinstall the plastic fender flare and caulk with proflex.
This is basically what I was originally suggesting except using eternabond instead of undercoating. Except, I don't know if eternabond is able to withstand road salts but undercoating certainly should be.
