Cummins12V98
Jan 18, 2019Explorer III
Wild Card wrote:Cummins12V98 wrote:
OK all you knowledgable people WHY have we not heard about CP4.2 pump failures like we used to??????
All mfg have upped the fuel filtration systems. The CP4.2 does not like any moisture. All diesel fuel contains some moisture and contaminants.
Higher pressure pumps simply can not handle contaminated fuel. You cant fix the fuel problem so you must be able to treat the fuel problem.
So I wonder if CUMMINS made RAM change the under bed filter from the spin on RAYCOR to the new canister system for this reason?????
