Bigfoot_affair
Jan 18, 2019Nomad II
Huntindog wrote:Perrysburg Dodgeboy wrote:The .1 is single piston (used in smaller motors such as the VW) and the .2 is a 2 piston for larger motors such as the GM/Ford, and now Ram HDs. The .2 IS NOT a revised pump... Just a 2 cylinder pump.Bigfoot affair wrote:
LOL, you are wrong!
The .2 doesn't mean revision, it means that it is a two piston pump. CP4.1 one piston, CP4.2 two piston.
Yes, internet is full of CP4.1 and CP4.2 failures, I think you already know but just choose to think its ok because Ram/Cummins is now using it... unreal!
I have not heard of anyone having any problems with the .2 pumps. I have one in my Ecodiesel and it is in Ford and GM diesels. When Ford came out with the 6.7 PS both Ford and GM had many CP 4.1 pumps fail.
Then Bosch went to the CP 4.2 and no more failures. At least not like we where seeing with the .1 pumps. Are there .2 failures, yes but nothing near what the .1 pumps where failing.
The difference is Ford flat out refused to protect their customers and GM stepped up and warrantied their trucks.
I would not think twice about buying a diesel with the CP 4.2 pump no mater the maker.
Don
They all have catastrophic failures that cost about 10K to repair.
GM quit using them around 2017. They paid out a LOT in warranty claims. For did not pay out so much, as they denied a lot of claims. They still use the CP4.2.
Isn't that what I said? The Ram crowed are like horses with blinders on...
The biggest problem for the CP4 is North American fuel and the amount of lubricity in it, sure water and poor filtration are factors as well. People just need to know that the CP4 is fragile and doesn't take much to cause problems.. Google "[COLOR=]Bosch CP4.2 lubricity"
I honestly think that this has been going on for so long people are not posting about the failures as much, just the cost of business of you want to drive a LML Duramax or a 6.7 Powerstroke & now Ram with the Cummins...
Yes, you have 5 years or 100k to have it fixed under warranty. What good does that do you when your on vacation sitting on the side of the road...
I am very surprised that Ram went with this pump on their new 2019, maybe GM has the rights to the Denso pump now fitted to the L5P?
