gmcsmoke
Jan 22, 2019Explorer
Wild Card wrote:gmcsmoke wrote:Wild Card wrote:gmcsmoke wrote:Wild Card wrote:Cummins12V98 wrote:
OK all you knowledgable people WHY have we not heard about CP4.2 pump failures like we used to??????
All mfg have upped the fuel filtration systems. The CP4.2 does not like any moisture. All diesel fuel contains some moisture and contaminants.
Higher pressure pumps simply can not handle contaminated fuel. You cant fix the fuel problem so you must be able to treat the fuel problem.
yeah well what about all the 2011-2013's driving around with OEM filtration for that MY? where's the catastrophic failures?
I am not going to answer it for you but a simple Google search will find your answer.
so you don't know then
No! They have problems. You want me to supply links and verbiage to back it up. I have already done my homework and know the answers. I feel you are in front of a computer and can do your own research and answer your own question.
posting a couple "horror" stories doesn't prove anything other than a few people can make a lot of noise.
so either all fuel makers radically fixed these contaminated fuel issues or the issues weren't as wide spread as some would have you to believe.
44,070 PostsLatest Activity: Aug 05, 2026
