4x4ord wrote:
Cummins12V98 wrote:
Travlingman wrote:
Cummins12V98 wrote:
"The computer is applying the wheel brakes both truck and trailer."
How do you know if the brakes were coming on the trailer on this test? Maybe the engine was doing what it needed with the trans?
Right past the 2 minute mark they say that it is using the truck and trailer brakes and also making the lights come on both.
Thank you!
Missed that part.
I personally would want to disable the trailer braking if I want to. From my weights and knowing I can hold 34k on 14% grade the test truck should have held without the trailer braking.
On your Ram does the boost gauge read reverse HP while the exhaust brake is working? What is the highest value you've seen it display?
Yes it does, I will have to look at old pics to see.
Just looked the pic on the 14% grade the gauge is blinded by the sun!
