ShinerBock wrote:
FishOnOne wrote:
ShinerBock wrote:
FishOnOne wrote:
ShinerBock wrote:
FishOnOne wrote:
So to summarize:
Brake Applications:
Ram: 0 (Auto Brake assisted-unproven theory by Ford fanboys)
Ford: 5
GMC: 9
Time:
Ford: 10:20
Ram: 11:32
GMC: 11:47
MPG:
Ram: 2.5 mpg
Ford: 2.4 mpg
GMC: 2.4 mpg
There, I fixed it for you.
I would still love to see how these trucks do at 80F or even 100F.
I agree with testing at 80F or 100F but I doubt the order of performance would change.
And now your ok with reporting the computer mpg when you have always reported major errors with these systems.
TFL reported the brakes were part of the braking system so if you don't like that or agree with it go debate it with them like you do the Australian.
I feel the result will be similar to last years test if it were 80F. I don't
I have stated before that I don't think the computer is accurate with a lot of stop/starts of the engine. The more start/stops are in the tank average, the more it is off based on my experiences. I have also said it is fairly accurate going from point A to B without turning off the engine.
I like to report all the data(good or bad) and let the people decide for themselves instead of only giving them part of the information because of some bias. Mr Truck has reported many inconstancies before and I doubt this would be the last. After all, he also stated the truck/trailer's brake lights were on and yet they were not. Unproven theory by a Ram fanboy
Just as a reminder that the previous 2020 Ram and GM trucks Ike pull had 2 brake applications with less weight. With 30k lbs the GM had more brake applications but the Ram had less.
Give me a brake... :W
Yeah, because they did not have it on auto like I have been saying for the past two years. Auto works better if the truck is doing the shifting. Full mode is best used if you are shifting manually which they do not do.
I think the Powerstroke will get heat soaked at 80F and would have to cut power just like it looked like it did last year.
Also,it is not an unproven theory that they the brake lights were not one. It shows it in the video when they were behind the truck. And it is not a theory that Mr truck has been wrong before.
I thought the Ram was set to automatic and the cruise control wasn't set on so the system would not apply the brakes.
The Ford wasn't heat soaked as it wasn't pulling as strong from the get go. From what I've been reading this new 2020 pulls really strong compared to the '19.
If Mr. Truck was wrong the chaser truck had plenty of opportunities to see if the brake lights were not on and they could have simply edited Mr. Truck's comment out if he was wrong. There was only very short clips of the chaser truck behind the Ram. So no I don't agree with your theory.
