srt20 wrote:
IIRC CO requires ALL vehicles to have chains in the vehicle on passes. If you get in a crash and block lanes of traffic without having chains IN the vehicle its a $15xx fine.
I was just on the IKE last week in a truck and trailer with no chains, luckily not snowing. But I was a bit surprised at the signs regarding the chains. I thought it was trucks with trailers that didn't have snowflake tires that required chains.
Lots of darned traffic on that road....There was no way we could go up the west side (side that TFL uses) without getting off the go pedal because of traffic, semis going slow, cars go fast.
I was in a SRW Duramax that easily handled the IKE, of course it had a pretty light load, 6000ish. Had LOTS of brake applications on way down east side because of traffic.
Washington is similar, but if You have a 4X or equal, and get into a wreck, your fault or not, no chains "ON" and with you, its a $300-400 fine ticket. Assuming all others need chains but AWD/4wd. My old dually, and my 96 SW K3500 were both licensed over 10K GVW. So even if I have snowflake tires, "chains required over 10K gvw" I need to chain up, even tho both were 4wd. Altho most LEO's looked the other way..... it could get expensive if something happened. Towing my TT in the winter to the local pass, also required chains when the over 10K chain up sign is out. As I was now at 15-16K literal lbs combined.
Here it is only the actual GVW potential that matter, commercial or private, does not matter. Will assume based on other states I've traveled in, in the winter months, they have very similar laws to Washington as to who has to carry, use at given times.
Marty
