Perrysburg_Dodg's avatar
Jun 11, 2019
2020 Ecodiesel specs
FCA
tfltruck ram 1500 ecodiesel
The fact that Ram is running a 8 speed as opposed to Ford and GM's ten speeds is not an issue. Here is why, the ten speed is never going to be able to hold the top gear and maybe the top two gears unloaded and they will never hit them towing. You simply can not run fast enough to hold those gears. The ZF nine speed will not hold the top gear until you hit 78 mph and that is an issue for customers. They complain that the trans shifts in and out of gear all the time.
Don
